Re: spluttering water dispenser
Usually changing the rear pcb situated at the rear right of appliance behind inspection panel sorts this fault but can also be a front selector pcb fault aswell. Usually these boards are changed in tandem under guarantee but are quite pricey if you have no warranty.
To obtain correct spare you will need to contact spares@ with the 85….. number situated on side of wall in salad area of appliance.
Or contact repairs@ for a local engineer to confirm fault.
