spout on servis door gasket
Home Forums Public Support Forums Help And Support Washing Machine Help Forum spout on servis door gasket
  • #59351
    phil1966
    Hi colud anybody please tell me if you have to seal the drain spout onto the drum or just pop it in. if i do need to will silicone do the job.
    thanks phil
    #337890
    Simon46
    bazza500
    Re: spout on servis door gasket
    I’ve never used anything on it and not had a leak.
    #337892
    helo_75
    me either.. clean it off, and use a bit of lubricant to ensure it seats correctly
    #337893
    EFS
    So why did they bother to glue it in the factory?
    It won’t leak much if you don’t glue it and won’t fail within the 90 day warranty 😉
    I always glue it in but I am a perfectionist.
    Steve.
    #337894
    phil1966
    i used a bit of heat and water resistant silicone in the end thanks for everybodys advise. i didnt think it needed anything on it but as somebody had said it was from factory.
    Thanks phil
    #337895
    RocketMan
    I do these on a reasonably regular basis – two blocks of flats with one in each. I haven’t had a PLI claim yet and don’t intend to. For the sake of an extra couple of minutes, not worth the hastle. Also, the last batch of seals I’ve used the rim around the spout was not as large as the original and doesn’t feel as though it would hold by itself.
    I’ve no doubt it would be fine without debor and respect your choice not to use it. I’m just a bit of worrier and like to sleep at night. 😉
