Squeaky Hoover TD
  • #34035
    Model TV30 .
    Only squeaks in one direction, changed jockey pulleys and a frayed belt, ( what an arse of a job, worse than most Hotpoint dryers) .Seemed fine when I left it but customer reports that it is squeaking again. I did lubricate the two drum support wheels at the front. Could these be causing the squeak or could it be the copper earthing strip at the back of the drum?
    Re: Squeaky Hoover TD
    iadom wrote:I did lubricate the two drum support wheels at the front. Could these be causing the squeak or could it be the copper earthing strip at the back of the drum?
    I’m sure the front wheels are just fine in that case Jim. More likely the rear shaft/bearing I would think? Cabinet alignment also an issue like with Hotpoints? Most TV30’s have drum shaft and bearing problems at some point and they’ve modified the drum too to address the problems over the years. :rolls:
    #240982
    Strange why it only sqeaks in one direction if it is drum shaft though.
    Something in your in-box.
