SR 2028CVW error code top digit on last 8 of fridge side
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum SR 2028CVW error code top digit on last 8 of fridge side
  • #69060
    mashood
    Hi can someone please tell me the following error code on my fridge freezer model SRC 2028CVW please.
    The top digit of last 8 (on the fridge side) on digital display blinks. No other light or digits are displayed. No buttons on either side of teh digital display work.
    The fridge freezer just stopped all of a sudden. Have tried switching it off now for 5 days bust still the same issue on plugging it back in. The light inside the fridge works but there is no cooling. The freezer is also not working.
    Bought the fridge freezer in around 2004 from John Lewis.
    what is required to fix the above issue? is it an easy / cheap fix?
    Really need help as soon as possible as have been without a fridge for a week now.
    #373584
    Re: SR 2028CVW error code top digit on last 8 of fridge side
    hi
    ice maker required. e-mail me if you want one.
    samsung@ffrservices.co.uk
    Bryan
    #373585
    SAMURI
    The wire’s on the ice maker sensor under the ice tray will be broken.
    You can sometimes solder them together but it is better to replace the sensor or icemaker.
    Bob
    #373586
    mashood
    No it was not the icemaker issue – the problem was Defrost issue – see following url for detailed answer
    http://www.fixya.com/support/t12497903- … d=21370724
    #373587
    SAMURI
    The link answer is for a different fault, display fault is for the icemaker.
    Bob
    #373588
    If you got the answer on fix you why ask again ?
    The correct answer is the ice maker issue.
    Bryan
