Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › SR-S2028CVW
- This topic has 3 replies, 2 voices, and was last updated 17 years ago by
admin.
April 6, 2009 at 12:38 pm #44797
KeymasterHi All
Having followed threads to solve my problem on the fridge side of my ff, (evap panel and all sensors replaced)
my new problem is on freezer side, flashing display -18degrees although temp in freezer much higher,
removed evap panel to find some sign of fan in back of panel getting so hot that its started to melt the adjacent surface in freezer,
your threads seem to lead to defrost sensor/defrost heater, can you confirm that replacing these may solve my prob.Rod
April 6, 2009 at 12:44 pm #282407admin
KeymasterRe: SR-S2028CVW
This was posted for rob,
The fault your listing isnt a common problem,to cause the rear liner to distort would take an excessive amount of heat so I would imagine that its just creased.
When the temprature lights are flashing t doesnt mean that its the freezer that is causing a problem on this model.It could be the fridge side also,Has the defrost heater been checked?
Bryan
May 26, 2009 at 1:37 pm #282408RodBT
ParticipantRe: SR-S2028CVW
Hi All, Sorry for delay, and thanks for response,
work has taken me away from home.in answer to whats being done, i have fitted new modified evap cover, and defo sensor and thermal fuse, on fridge side. having changed these does it narrow down possible problem??? 😀 I am now committed to not being beaten by my Samsung, and your help will help me win the battle. Many thanks in advance
RodbtJune 1, 2009 at 4:13 pm #282409RodBT
Im finding my feet as to how to work the forum, and would like to re ask my last question wich i have copy to the bottomof this message, i hope someone can help
thanks again in advanceRodbt.
work has taken me away from home.in answer to whats being done, i have fitted new modified evap cover, and defo sensor and thermal fuse, on fridge side. having changed these does it narrow down possible problem??? I am now committed to not being beaten by my Samsung, and your help will help me win the battle. Many thanks in advance
Rodbt -
