SRL 3916bss defrosting
Viewing 1 post (of 1 total)
  • #51429
    Johnnyboy
    Hi Folks, This one works until it reaches temp then stops dead until you switch it off and on, replaced the front pcb as the heaters seem to work ( no ice build up behind plate)if the sensor didnt work then it should turn into a sauna, switching it on /off just resets the cycle but why it wont start by itself is a bit of a mystery.
    Cheers Johnnyboy
