Re: Stacking freezer + tumble dryer
There is no such kit I`m afraid, the other problem you have is that you have a heat source and a cold source above each other which creates a problem in the running of the freezer especially.
The only way I can think of would be to, have the freezer at floor level, mount a shelf on the wall with a thin piece of tin / metal on it to deflect any heat away from the freezer. If the dryer is a vented one you will also need to keep the hose away from the freezer as well.
To stop the dryer being pulled off the shelf, you could make up two straight metal strips say 6″ long with a hole drilled through each end, screw one end into the worktop lid and the other into the garage wall. A bit Heath Robinson I know 😉 but it may get you out of a fix.
HTH
Don
Electronic fridge thermometer click here
