stalling motor
  • #79567
    dpr1974
    Afternoon, i’ve got a hoover hnf 7148 and the motor has real trouble turning over with washing in it.
    so i tested the whole thing (motor) and everything is within the correct readings. i then fitted a near identical motor and it turns perfectly, but the readings from the second motor are the same as the first motor. so any ideas to the stalling issue?
    #409719
    Re: stalling motor
    Old motor: current increases under load?
    You could always check the current under load of the new motor, then stick the old motor back in and compare. 💡
    More likely the armature breaking down under load rather than the stator I would think.
    #409720
    dpr1974
    Re: stalling motor
    i did that already, same reading. i assumed from the beginning that it was the armature, just a bit puzzled with the identical readings though. guess age is the factor in this. many thanks
    #409721
    Re: stalling motor
    dpr1974 wrote:guess age is the factor in this.
    Yeah tell me about it. I’m still drawing the same power but oh my aching bones. :clown:
