Standard sizes and variations?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Standard sizes and variations?
  • #21856
    JLatimer
    I want to put a freezer into a place where I’ve restricted depth. A freezer
    with a depth of 500mm to 510mm would be ideal. Are these available?
    A built-in unit without the attached “kitchen unit door” would be OK,
    I’m not all that concerned about the look of the thing. Some sites I’ve
    looked at have dimensions, butl seem to specify different depths for the
    same model, which is a bit of a nuisance!
    #192756
    don
    Re: Standard sizes and variations?
    If this is under the worktop size you are looking for then Lec produce a small one the U5026W which is a mere 56cm deep but it`s only a nrrow 48cm wide so limited storage. All the others seem to range between 59 and 60cm. As for built under the depths are mainly 54.5cm, if using without the fitted door you will probably need to fit a handle, as the handle would be on the timber door under normal circumstances.
    Don
    #192757
    JLatimer
    don wrote:If this is under the worktop size you are looking for then Lec produce a small one the U5026W which is a mere 56cm deep but it`s only a nrrow 48cm wide so limited storage. All the others seem to range between 59 and 60cm. As for built under the depths are mainly 54.5cm, if using without the fitted door you will probably need to fit a handle, as the handle would be on the timber door under normal circumstances.
    Hi Don, thanks for your reply. The Lec U5026W would be absolutely
    *wonderful*, if only I could fit it in sideways! I have found a thing
    called a “smeg VR120B”, which 365electrical say has dimensions
    (WxHxD) 58cms x 81.5cms x 50.5cms. This is nearly 300 quid, though;
    plenty enough IMO. That’s a built-under, although I really don’t mind
    whether it’s built under, free-standing under counter, or what – as
    long as it’s not far off 500 mil! Anything would do, but it can’t be deeper
    or I’ll have to make a big hole in the wall! Any other ideas? I suppose
    I could put a freezer outside, but that’s not remarkably convenient!
    #192758
    don
    JLatimer wrote:
    I have found a thing called a “smeg VR120B”, which 365electrical say has dimensions
    Sorry to say but it`s 54.5 on the depth. Hit on the technical drawing link here http://www.smeguk.com/CucinaSelection/P … eq=3518729
    You may have to consider another location or have a work top model like the Lec U5006W which has sizes of H53cm W50cm and depth of 51cm.
    Don
    #192759
    JLatimer
    Arghhh! THUD THUD THUD (sound of forehead on brick wall).
    don wrote:You may have to consider another location or have a work top model like the Lec U5006W which has sizes of H53cm W50cm and depth of 51cm.
    Tap, tap, Google, Google… um. It’s rather tiny. Not everyone can fit in a
    600mm worktop… isn’t there any call at all for reduced depth units?
    Humph. After looking agaim, I find that I could *just*, if I do a little bit
    of modification to the existing space, fit in *something* as long as it’s
    less that 580w, 560d(max), doesn’t matter about h within reason. If it
    was 550w I could put in a hod of coal next to the thing. Is there
    something that would fit the bill?
    #192760
    don
    one of these then :bang: 😆
    Eureka cracked it :tup:, the best option I can find is this little beauty. Whirlpool AFB820/3 it stands 87.3 high 54.0 wide and 54.5cm deep http://www.whirlpool.co.uk/app.cnt/whr/ … subcatid/9. As you can see it is designed to fit into a housing at waist level so a little mod maybe required to allow air flow underneath and to allow the door to open. Don`t forget about the handle issue also.
    Don
    #192761
    JLatimer
    Sounds good! However I get “The Following Error has Occured While Processing. Require information is missing or incorrect. Please contact web administrator.”. Bother.
    #192762
    don
    Think it may have been me 😳 try this one 😉
    http://www.whirlpool.co.uk/app.cnt/whr/ … prodid/599
    Don
