Statesman W1011 w/m
  • #64777
    larry
    I have a strange fault with a statesman w/m it seems to work ok until the heater comes on then after heating for about 3mins it cuts out and the ready and end lights continually flash red it must be some sort of fault code but i don’t know what,please can anyone help.
    #358043
    Re: Statesman W1011 w/m
    Some of these Amica Codes might give you a clue, some of these made by Amica AFAIK.
    Might be in THIS one though. :con:
    gandh1
    nine jim, this is the vestel model, there is a basic fault code identifier in the back of instruction book, but id be looking at the element anyway. the w1011 is about 6yrs old now (blue front) or 5yrs if its the black print, either way these were the solidist ones they made! easy thing to try is to put it on a cold wash, not a 30, an actual cold one on wool cycle iirc, and it should work fine if the heater/ntc is dodgy.
    worth ringing 01452883009 to get parts/advice. their parts arent expensive.
    #358045
    gandh1 wrote:nine jim, this is the vestel model,
    I guess you mean “nein” 😀
    Thanks for that info . 8)
    gandh1
    typo. you know im typing dyslexic
    #358047
    Just checked the ISE/Vestel codes, Ready and End flashing is a motor/wiring/connections problem.
