Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Sticking main oven fan in Bosch HBN9360GB/06 FD8109
- This topic has 6 replies, 3 voices, and was last updated 15 years, 1 month ago by
MrOtford.
February 28, 2011 at 7:35 pm #61365
MrOtford
ParticipantHello
The fan in the main oven of my Bosch HBN9360GB/06 has a tendency to stick when the oven is switched on, and needs a gentle prod to start spinning. Looking at the Bosch site I see that 261675 at £75.01 plus p+p is the fan motor.
My question is: do I have to remove the oven from its housing to replace the motor or can it be done in situ? And is it a straightforward procedure?
Many thanks
Richard
March 1, 2011 at 1:39 pm #345852gdownes
ParticipantRe: Sticking main oven fan in Bosch HBN9360GB/06 FD8109
Richard
It looks like it’s a removal job to acess the back and removal of the motor should be easy after taking off the fan and removing the rear cover
George
March 1, 2011 at 10:41 pm #345853MrOtford
gdownes wrote:Richard
George
Thanks George, so it’s removed from outside? Will there not be plenty of insulation in the way?
TIA
Richard
March 2, 2011 at 3:15 pm #345854Specialist01269
If there is insulation in the way just gently tease it apart, once you’ve replaced the part/parts it will pull back over.
PLEASE REMEMBER: POWER OFF FIRST, Getting :zap: can seriously shorten your life.March 2, 2011 at 7:26 pm #345855MrOtford
Specialist01269 wrote:If there is insulation in the way just gently tease it apart, once you’ve replaced the part/parts it will pull back over.
PLEASE REMEMBER: POWER OFF FIRST, Getting :zap: can seriously shorten your life.Thanks
Do you agree with gdownes’ suggestion that the fan motor is accessed from outside the back of the oven and not through the interior?
Rgds
Richard
March 2, 2011 at 8:16 pm #345856Specialist01269
Yes I do, George knows his stuff.
March 2, 2011 at 8:22 pm #345857MrOtford
Specialist01269 wrote:Yes I do, George knows his stuff.
And George, if you’re reading this, no offence meant 😳
Rgds
Richard
