still stuck with this indesit DI 620uk D/Washer.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries still stuck with this indesit DI 620uk D/Washer.
  • #14688
    TELL
    the fault codes on the forum do not tie up with what is happening. the codes are for a DI 61type 100 timer. this does not have timer, but a pcb in the top L/H ofthe control panel . goes at start of programme (any) does fill, wash 1st rinse, drains then shuts down, stops. 3rd light flashes, have checked pump,drains full pipe, all clear. reset on another prog, does the same??.
    there is a little diapragm with micro switched connected to circ/pump hose had that off, but found it very hard to operate, nearly blown my guts out to operate it. has that any bearing to it??.
    TELL..
    #160464
    johnnyj
    Re: still stuck with this indesit DI 620uk D/Washer.
    If the drain pump is clear etc sounds like pressure sw, pressure chamber, pressure hose possibly blocked, on these machines if press sw does not reset in 4 mins during drain this fault occurs, if thats okay i’d guess its the module, hope this helps.
    #160465
    johnnyj
    Sorry my mistake is it the 3rd light flashing on its own if so its a short or open circuit thermistor it may be a broken wire or similar, other than that you’l need the module part n/o C00097890.
    #160466
    TELL wrote:the fault codes on the forum do not tie up with what is happening. the codes are for a DI 61type 100 timer. this does not have timer, but a pcb in the top L/H ofthe control panel .
    A bit misleading, should say module and not timer, will alter it. 🙂
    Your machine has the 100 bit controls.
    #160467
    TELL
    thanks lads, not so confused on the contradicting timer/module fault codes iadom, and johnnyj, i think thats a definite on the module. there is a little diapragm with micro switched connected to circ/pump hose had that off, but found it very hard to operate, nearly blown my guts out to operate it. has that any bearing to it??. what is it??.
    TELL..
    #160468
    johnnyj
    Not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure but i’m sure its the timer/valve on the end off the motor which diverts water to to the top spray arm only or to them both ie if a half load is selected on some models only the top is supplied others spray intermitantly between the 2 spray arms.
