stoves 050564149
Viewing 1 post (of 1 total)
  • #89211
    char14lew
    this range oven was only giving very low heat from the main fan oven.The thermostat clicks as normal when turning on and when tested with the meter changes resistance when turned on.The heating element has normal resistance readings and meggered ok,so could it be the timer,also Is there anything else to check and the best way to get to the thermostat,timer please?
    help most appreciated!
    Darrell
