Hi All
I have a couple of questions on this unit:
1. Does anyone have a wiring diagram for this oven as the customer has changed the grill regulator and I am not sure that it has been done correctly (it does turn the grill on and off but it only regulates on position 5 apparently).
2. This unit appears to have some plastic “slide pads/feet” on the bottom of the door that slide against the chassis when the door is opened to kick the bottom of the door out – does anyone know what the part number is for them?
Thank you
Jem
