Re: Stoves 1200 DFa Range – Main oven door hinges
Oh, deep joy 🙂
Drop the door down, put two small rods (or screwdriver blades) through the bars that extend from the cabinet (spring loaded), slide the inner glass out, there’s two small plastic “stoppers”, you’ll see the heads just protuding past the left and right hand metal parts near the bottom, pull them out (tight fit but you should have new ones in the kit). Once they’re out, the door will slide off of the hinges (plastic foot attached to the bars that are now restricted from flying inside the cabinet).
Take the feet off, fit the new ones and reverse the above 😀
I hope that makes sense. If you want, PM me for my mobile and phone me from the house if you get stuck.
