Stoves 600 SI DO DL Gas oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Stoves 600 SI DO DL Gas oven
  • #38204
    SMaric
    When the oven is of the white dot indicator avove the control knob no longer returns to the correct position
    This only seems to be anindicator problem as the gas is being truned off corrctly
    So really the problem is that – because the dial doesn’t start at off we no longer know what Gas mark / Temp we are setting
    Is ther a way to get to these indicators – I presume something has allowed them to slip
    #258070
    helo_75
    erm, no its a knob and a bezel
    if its not one of those, its the thermostat thats faulty, the latter being more probable
    #258071
    wsts
    helo_75 wrote:erm, no its a knob and a bezel
    This one is a plastic disc behind a glass fascia, stoves had a problem with it and came out with an update, a small metal disc that stuck to the plastic one to strengthen it.
    #258072
    SMaric
    wsts wrote:This one is a plastic disc behind a glass fascia, stoves had a problem with it and came out with an update, a small metal disc that stuck to the plastic one to strengthen it.
    That seems like what I’ve got
    Any idea how to get at them to re-allign the disc with the off position
