Stoves 61EHDO – Uneven cooking
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves 61EHDO – Uneven cooking
  • #66744
    OLLIE2806
    Model: 444445571 & Ser: 80928371
    Hi guys,
    I have the above free standing electric cooker that is cooking unevenly in the main fan oven, On half seems to cook ok and on side (usually the right hand side if your facing the oven) over cooks / burns everthing.
    The fan seems to run consistantly fine.
    Im a bit bit puzzled.
    Thanks in advance
    Ollie.
    #365085
    Poppins
    Re: Stoves 61EHDO – Uneven cooking
    Have you checked to see if the door is sealing? With the fan running, press the door working your way around the edge to see if the sound of the fan ‘changes’ because you have sealed the door better and prevented air loss. The change is likely to take place on the left hand side given that the burning is on the right. If this is the case then it could be the door seal or a distorted door frame or hinge or a mixture of the three. Check also to see if the catch is actually holding the door tight. I don’t recall there being an adjustment on this model so you would require a new catch if this is the case. If there is severe air loss then you will often see indications of this as burning or brown marks on the enamel where it leaves the door.
    Most of the time it is loss of air around the door but if the door and seal prove to be ok then your next option is the heating element. This model has three turns which can give rise to ‘hot spots’ often before it fails. At its worse it could be all of the above! :rolls:
    HTH 🙂
    Chris
    #365086
    MickGeorge
    Hi Ollie
    Did you manage to cure this?
    I have similar problems with a Cannon with the same fault (see other post) and just wondered if you had sorted.
    Mick
    #365087
    OLLIE2806
    I’m pretty sure I just changed the fan element mick and that cured it.
    #365088
    MickGeorge
    Thanks for the reply Ollie
    Might try that first then as I think I might have one on my van.
    Thanks for the reply.
    Mick
