Stoves 720 EF Oven Cuts out when hot.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves 720 EF Oven Cuts out when hot.
  • #29426
    Twoten
    The above oven cuts out when main oven is used and gets hot.
    On testing I find I don’t get a neutral to the cooling fan. There are two thermostats in the outer casing, one directly above the convection fan motor the other in the control panel area, both are closed circuit.
    The neutral is supplied via a control PCB in the control panel area.
    Can anyone tell me if this cooling fan should come on as soon as the oven is switched on or if there is a stat that should switch it via the control board which I assume is a fan over run PCB?
    Does anyone have any tech info/wiring diagram for this model or any ideas?
    Thanks,
    Keith.
    #223063
    mike412
    Re: Stoves 720 EF Oven Cuts out when hot.
    Hi Twoten.
    I have a wiring diagram for this model, just need an email address. please PM details.
    Regards, Mike.
    #223064
    Twoten
    Thanks for the wiring diagram Mike,
    it looks as if the board is triggered by a neutral from either the grill regulator or one of the oven thermostats. As there is a permanent live and neutral and the fan doesn’t run when any of the elements are turned on I can’t see it being anything other than the PCB.
    Thanks again,
    Keith.
