Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Stoves 900DFA, model no. 059056601, serial no. 002062
- This topic has 9 replies, 8 voices, and was last updated 12 years, 12 months ago by
Martin780.
April 14, 2013 at 10:22 am #75011
Martin780
ParticipantThe main oven thermostat Tstat,stat type 43THC83/HO (Stoves part no. 082269300) is no longer manufactured. Has an alternative thermostat been identified that can be successfully fitted to the 900FDa range cooker?
I see there are some universal thermostats available from UK Whitegoods, but don’t know if any of these is suitable.
Many thanks
Martin780
April 14, 2013 at 12:12 pm #393590Specialist01269
ParticipantRe: Stoves 900DFA, model no. 059056601, serial no. 002062
Hi: If you contact the UKWG shop staff, they will be able to tell you if a replacement is available.
May 2, 2013 at 12:01 pm #393591jonners999
Would be interested to know if you managed to fit a replacement thermostat?
I have a Stoves 900DFa Cooker in very good order, other than the thermostat has packed up. Details:
Model No: 059056600
Serial No: 40463940
Part No: 082269300 (43THC83/HO)
Can anyone out there fit a kit, different thermostat to this or have a universal thermostat that would work? We are in post code HP14 – High WycombeMay 2, 2013 at 12:05 pm #393592kwatt
KeymasterRe: Stoves 900DFA, model no. 059056601, serial no. 002062
So far as I can see that thermostat is obsolete with no alternative available I’m afraid.
June 16, 2013 at 12:45 pm #393593rich-pickings
Hi, I have one of these thermostats in stock, let me know if tour still looking
RichardSeptember 14, 2014 at 7:02 pm #393594clone123
Hi I have been looking around for about a week for the oven thermostat part number 43THC83/HO with no joy did any of you guys find a supplier or a alternative thermostat mine is model no. 059056600 but as you can see the part number is the same as yours
September 14, 2014 at 7:21 pm #393595kwatt
The only stat that shows up as available for that cooker is this one:
http://shop.ukwhitegoods.co.uk/08255800 … thermostat
But, that is using the original model of 059056600 and it sis an EGO 55.17069.090. It is possible that this is a suitable alternative but I can’t see that as Stoves service info is, will we say, not wonderful.
The original 082269300 is definitely completely obsolete so unless you happen across someone with one of the shelf you’re not going to have any joy as none of the major suppliers have any.
September 15, 2014 at 9:17 am #393596clone123
Cheers Kwatti I was looking at that thermostat as an alternative but two things I am unsure about one being the bar for the knob doesn’t look long enough to put the original electric switches that fit on it and come though the front of the cooker to fit the knob on and the other is if the wiring on the back being different don’t want to blow anything. I know there is only three wires two of which go on the same connection and one on another.
November 18, 2014 at 7:04 am #393597Leeuk1977
clone123 wrote:Cheers Kwatti I was looking at that thermostat as an alternative but two things I am unsure about one being the bar for the knob doesn’t look long enough to put the original electric switches that fit on it and come though the front of the cooker to fit the knob on and the other is if the wiring on the back being different don’t want to blow anything. I know there is only three wires two of which go on the same connection and one on another.
I have this problem where the three wires have came loose …. Can you tell which place they should go please ? … Many thanksDecember 8, 2016 at 11:51 am #393598suddies1
rich-pickings wrote:Hi, I have one of these thermostats in stock, let me know if tour still looking
RichardHi mate, do you still have one of these?
