Stoves 900DFA overheating
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Stoves 900DFA overheating
  • #59125
    Nicky321
    We have a stoves range oven approximately 8+ years and think it is a Stoves Gourmet 900DFA Duel fuel range cooker, however I have lost the user manual and are now having problems with the interior upper fan which keeps the housing cool. This is no longer functioning and causing the front control dials to get extremely hot and the main main oven to switch off due to overheating. It does switch back on after quite a while when its cooled down and continues cooking. Is there anyway to obtain a user manual and what parts are required to fix this appliance. Thanks for your time.
    #337010
    Applianceman2010
    Re: Stoves 900DFA overheating
    Hi, is he fan ok do you have a tester to see if it is ok?(i ask this because the fan is usually braught on by a heat sensitive cut-out) if the fan tests ok and is not getting voltage to it it is prob this. Also good luck getting parts from Stoves they take FOREVER!! lol
