stoves 900ef
  • #42157
    wilf
    model 059040404 customer reporting main oven works ok but cuts out completely on very high temps i.e. 220 and above I assume that its most likly the toc fitted in the back just above the motor/ element.
    anyone know the part number?
    thanks
    wilf
    #272562
    Re: stoves 900ef
    Typing 900ef into Masterpart’s search brings up your model but no parts listed 🙁 . However choosing a similar model brings up a list of parts of six pages including “thermal switch” 082808901. This comes up on Connect as “Stoves thermostat cutout” but is specified as 100 deg which sounds low for your description. However you might be able to tell from the pic.
    Would suggest buying from Mpt cause they provided the part no. 😉
    Mike.
    #272563
    Re: stoves 900ef
    Is the cooling fan working?
    #272564
    wsts
    I would say the cooling fan is not working, if its the newer type it would be the fan itself if its the older type it will be the resistor gone.
