Look in the shop at part number 082233401. This looks like the one you need.
BTW are you sure the fan is faulty, if the fan is going slow or not at all it is usualy the little pcb at the back of the oven that causes the problem.
Thanks John, but sadly not the right fan, although I have seen those in other stoves ovens.
The old fan is kaput (burnt out) and has taken the pcb as well 😥
