Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Stoves 900EM Small oven door hinges
- This topic has 13 replies, 2 voices, and was last updated 5 years, 1 month ago by
Twoten.
February 11, 2021 at 2:14 pm #99118
Twoten
ParticipantCan anyone provide a part number for Stoves 900EM Small oven door hinges, please?
February 11, 2021 at 2:35 pm #475055electrofix
Moderatorputting this number into Qualtex brought up 082077803
which is the door slider. if this is correct then these are not a 1 piece hinge. there is a bar and a pin plus the slider. All held in place by a horizontal spring inside the case
have you got the proper model. With the age of this am expecting a number beginning 0505 but could be wrong
February 11, 2021 at 2:41 pm #475056Twoten
Participantelectrofix wrote:putting this number into Qualtex brought up 082077803
Sorry, 059042373 S.No: 000139
February 11, 2021 at 2:52 pm #475057electrofix
Moderatoryes is the slider one
have you looked at it ? whats wrong with it ?
February 11, 2021 at 4:18 pm #475058Twoten
Participantelectrofix wrote:yes is the slider one
Hi Dave,
Customer sent this. Thought I would check if the hinge is available first.
Keith.
February 11, 2021 at 4:29 pm #475059electrofix
Moderatorall you should need is new sliders
poss part no above
that bar coming out of the case is connected to a spring to pull the door in. the slider sticks out the bottom of the door.and stops metal to metal contact
February 11, 2021 at 4:59 pm #475060Twoten
Participantelectrofix wrote:all you should need is new sliders
poss part no above
The pin going through the bar is sitting at about a 45 degree angle to the bar. I have a video but couldn’t upload it. Should this pin be fixed or will the slider hold it in position?
February 11, 2021 at 5:27 pm #475061electrofix
Moderatorif you look at the pics of the slider its split. the bar goes in the split ( middle) and the pin goes through the lot making a hinge
when you see it you will realise its a very simple system
whats happened is the slider has fallen to bits. other bits may be worn but you will need sliders all the rest is metal
February 11, 2021 at 6:39 pm #475062Twoten
Participantelectrofix wrote:if you look at the pics of the slider its split. the bar goes in the split ( middle) and the pin goes through the lot making a hinge
Cheers Dave, I’ll book it in and take a look.
February 16, 2021 at 8:46 pm #475063Twoten
DaveHaving looked at the appliance the sliders and bar are different from the one relating to the above part number.
I have attached a photo of the original one.[IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”height”:”376″,”width”:”794″,”src”:”https://www.ukwhitegoods.co.uk/forums/filedata/fetch?filedataid=5734&type=thumb&attachmentnodeid=”}[/IMG2]
February 16, 2021 at 10:04 pm #475064electrofix
Moderatorpic seems to have failed
February 17, 2021 at 1:09 pm #475065Twoten
Participantelectrofix wrote:pic seems to have failed
Can you see this one?
February 17, 2021 at 1:32 pm #475066electrofix
Moderatoryes thanks
cant find anything on this probably because its old
to compound as far as i know the parts website for these has been down for months
i would try ringing stoves and see if they can email you parts listings/ breakdowns
February 17, 2021 at 9:31 pm #475067Twoten
ParticipantI called Stoves, they were reluctant to send a parts listing. They looked at the drawings and said everything in the door area is shown in red so it’s going to be obsolete!
I think I’m going to have a draw a line under this one.
Thanks for the help Dave. -
