stoves 900gdo
  • #89828
    HotDog
    Got to change door hinges on this gas cooker cant see any latches on the hinges to release them from cooker any advic how they come away from oven olso i am not gas trained am i legally ok to work on gas ovens as long as i dont touch any of the gas components :fire:
    #442685
    RickT
    Re: stoves 900gdo
    Open door. Remove inner glass. There should be a hole on each hinge insert where you can insert something like a drill bit. Remove left and right screw halfway down the door. The door should now pull off. From memory, the hinge is secured from the side. Once the screw is removed, the hinge assembly should just slide out.
    #442686
    HotDog
    Re: stoves 900gdo
    thank for that
