been out to this oven (model 059042316) and the main oven shuts down after 10-15 mins. On inspection, the cooling fan doesn’t run when the main oven is on, it will however run when the top oven is on. There is a pcb on the top of the oven. Is it likely to be this?.
Regards
Merv
Thanks, there is a main oven cut out stat at the back of the oven, which is obviously working. On the top of the oven there is a toc, and that is it, apart from the pcb.I think I’ll give the board a go, it’s only £11 so It’s worth a punt.
Merv
