Stoves Belling DW 602/2 Leaking
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves Belling DW 602/2 Leaking
  • #5537
    Kirk
    I went to this machine for it leaking I haven’t found where yet I picked it up still full of water, but on taking the concrete weight of the main wash pump seems to just float in and out and I wondered if this was happening on the wash cycle so then flooding?
    How do you get into it? is it the same as Bosch split the base from the tank?
    Thanks Kirk
    #111756
    Dave_Conway
    Re: Stoves Belling DW 602/2 Leaking
    If it’s a Brandt made dishwasher, then it’s a case of removing the side panels IIRC.
    Easy way to tell if it’s Brandt, is the timer right at the front of the lower section below the door on the left looking from the front ?
    #111757
    Kirk
    Yes Dave the timer is down at the bottom, I have remove side panels and rear weight can see the pump just floating on a rubber mount but the plastic base has it all enclosed.
    I want to know how you get access to it there is not enough room from the sides either, there also doesn’t seem to be any fixings to the rear to loosen off only at the front?
    Also has anyone else had this fault of loose pump leaking when it is washing.
    Thanks Kirk
    #111758
    Dave_Conway
    I know MFI issued a modified circ pump for their equivelent model (AHY8101/8102). I don’t recall replacing one though.
    MFI agent required for more info please for Kirk.
    #111759
    Kirk
    Hi Dave I found the base which is plastic has a seperate insert in the very bottom and is held in with four plastic lugs, so I removed pump and found that it has a small bellows that had a small hole in it, so problem now resolved.
    Thanks again for your help Kirk
