Re: stoves built under oven
well looked up your model and shorting a timer is an ok repair but it wont work on this model ( if number correct)
have not got very good pictures on this but i would look at the switches you use to set everything. if they are pushbuttons then use your meter to see if they close when pushed , also check power supply board for blown caps ( same fault as hotpoint modules)
if all this fails new cooker as some parts are obsolete
dave
