Stoves cooker cooling fan not turing off even after an hour
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves cooker cooling fan not turing off even after an hour
  • #41655
    dna
    Stoves cooker cooling fan not turing off even after an hour. I’ve change the thermistor because the main oven was over heating and this problem is solved but it still leaves the cooling fan on any ideas.
    Any help would be great
    #270881
    smartin
    Re: Stoves cooker cooling fan not turing off even after an h
    a rear waffle flankle could be the problem its next to the lower skrim, failing that a model number might be able to bring better results 😆
    #270882
    dna
    The model is 059050516 hope this helps
    #270883
    Seamy
    Some Stoves have a PCB on the back of the cooker that controls the fan, theres a large resistor that i remember causing this problem but i’m not sure if its same type of cooker.
    #270884
    Jonah
    Change the PCB, available from Qualtex at about £10
    #270885
    dna
    Do you have part number please?
