Hi there!
We have a problem with our Stoves gas cooker because the clock/timer is faulty.
The main oven cannot be turned on because the clock will not set and (I am assuming) the timer thinks that because there IS no time then it won’t allow that oven to turn on!
We have worked out that if you turn on the top oven’s grill the timer flashes after a while (like it’s reached the time to turn on the oven!) and the oven will turn on but after a while it will turn off again and we have to go through the same process to get it to start up again.
All very frustrating when trying to co-ordinate a sunday roast dinner!
Can anyone help… please! Is this an easy fix?
Thanks in advance…
