Stoves DF600 SI Grill – top oven fault.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves DF600 SI Grill – top oven fault.
  • #70540
    walnut
    Had 3 calls this week enquiring about faulty Stoves top oven / grill. The grill / top oven comes on when switch to the off position.
    The control is a single knob for both grill and oven.
    I think the part is manufactured by Invensis and was obsolete.
    Does anyone know of an alternative fix? I was thinking of wiring in a fan switch infrount of the thermostat that isolated the supply.(bypass the faulty thermostat).
    Any other ideas?
    #378340
    Simon46
    Re: Stoves DF600 SI Grill – top oven fault.
    Can you remember if you fitted a selector switch in front of this and did it work. Invensys switch is now obsolete and requires fitting both ovens selector switches with two new thermostats and wiring conversion. Expensive.
    Regards Simon
