Stoves Double Oven EFa 700H
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Stoves Double Oven EFa 700H
  • #76639
    Robint
    Help would be appreciated, my oven has recently started acting weird!! the bottom fan oven will heat to 140oC only and the top oven / grill is overheating and cuts out altogether, can anyone help please? the bottom oven fan is working, but I have been told that the fan should continue running when you switch the oven off to cool but my one does not, the appliance is about 3 years + old. Also, do you think it would be cost effective to have it repaired?
    Thanks again.
    Robin
    #399335
    Robint
    Re: Stoves Double Oven EFa 700H
    Robint wrote:Hi
    Thanks again.
    Robin
    Quick update, I removed the fan cover on the lower oven and the thermostat appears to work fine in that the oven heats up and cools down as normal, any ideas? any ideas all welcome, thanks. 💡
    #399336
    Simon46
    COOLING fan (seperate) behind oven should run after switch off. Controlled by pcb.
    S.
    #399337
    Robint
    Thanks Simon, I have ordered a new fan.
    Robin
    #399338
    Robint
    Simon46 wrote:COOLING fan (seperate) behind oven should run after switch off. Controlled by pcb.
    S.
    Changed the fan but still no joy, looks like I will have to buy a pcb for it!!!
    #399339
    Simon46
    Does it have a resistor in line? If so you need to test with meter as shorted fan may have blown it.
    S.
    #399340
    Robint
    Simon46 wrote:Does it have a resistor in line? If so you need to test with meter as shorted fan may have blown it.
    S.
    Hi, not sure about the resistor but the fan turns very slowly which would suggest power reaching, I have ordered the pcb board hope this works, need my oven back 🙁
    #399341
    Robint
    It’s working 🙂 new pcb done the trick. Thanks for the advice Simon.
    #399342
    Simon46
    No worries.
    S.
