STOVES DOUBLE OVEN Q720EMDO
  • #7522
    cornwell40
    Right this one could be a very expensive mis-diagnosis or a faulty timer sent out. 😥
    Customer complaint of oven won’t switch to manual setting.
    Went out originally and the timer is stuck in auto mode.
    Both ovens and grill function o.k but you have to set a 24 hour cook time to do anything.
    Finally got the new £ 105 timer four weeks late( the courier lost it), fitted it and …..the same fault. :eeek:
    It isn’t some kind of fault code is it???
    Go tell me it’s a common fault on this timer…..make my day …please!!
    Tony C
    #123867
    Kirk
    Re: STOVES DOUBLE OVEN Q720EMDO
    Tony the usual fault when stuck on auto is switch off at mains and on again, as you have changed the timer perhaps the other one is a faulty button as the new clocks don’t normally come with them.
    If you have done both best of luck.
    Kirk
