Re: stoves dual fuel grill regulator replacement
Beware not disconnect any Gas pipework if you’re not registered to do so.
If its Electrical the fascia panel comes off, 2 side screws on each side, some screws underneath fascia & sometimes 4 or 6 screws on top hob are screwed back into fascia, knobs off fascia panel should drop off, if not sometimes theres a single centre screw in middle behind clock which can catch you, think Dimpco would have any info you need for it.
