I have looked at the above oven because it cuts out after about 15/20 minutes.
The cooling fan doesn’t run. On checking I am getting a live to both sides of the cooling fan, no neutral.
Can anyone tell me if the cooling fan is supposed to run all the time oven is on or only when the outer shell gets warm?
Both stats (the one mounted above the oven cavity and the one on the top left rear) are both closed circuit so I don’t think it’s that, this is why I wondered if the cooling fan runs all the time the oven is on because logic suggests one of these stats would bring it on as the oven heats up.
Stoves were very helpful and sent a wiring diagram (unusual for a manufacturer to provide this sort of information).
Turns out the blue wire to the fan that should have supplied the neutral was connected to the wrong position on the selector switch and provided a live instead.
Don’t you just love it when someone else has already had a go!
