Stoves EL916 058587091 double oven cooling fan slow
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves EL916 058587091 double oven cooling fan slow
  • #31600
    Simon46
    The computer fan in this double oven does not turn. Replaced fan (old one smells burnt) turns at about 20 RPM. Live is direct from terminal block on rear of oven but neutral is fed off a PCB mounted on the top of oven. Would it be the PCB that is faulty as everything else works on the oven/grill?
    Regards
    Simon
    #231795
    Simon46
    Re: Stoves EL916 058587091 double oven cooling fan slow
    Have ordered from Stoves 082814400 PCB at £20.32. It has a green wirewound resistor on board. I expect this has failed?
    Regards
    S.
    #231796
    Simon46
    Received new board but no resistor on this new one. Is this correct?
    S.
    #231797
    Simon46
    Fitted board and fan all ok it seems 😀
    S.
