no mate,this isn’t the one.
the one i need has two retaining holes for the retaining screws.
the part number you gave me is for the one we stock which is the one with the one centre retaining bolt.
cheers.
john
Is it the correct power rating and dimensions, though?
If so, could you not (safely, of course, – one has to be so careful what one says on here these days) modify the bracket?
Mike.
PS: If you tap in, for example, “Stoves element” to Connect’s search box, it will bring up plenty of choices. You can then cross reference results to other sites etc.
