Stoves Gas Hob – GH607 HOB
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Stoves Gas Hob – GH607 HOB
  • #52714
    viv49
    GH607
    This gas hob is currently fed by LPG. Does anyone know if it is possible to use it on natural gas?
    Many thanks
    #312847
    A1TEC
    Re: Stoves Gas Hob – GH607 HOB
    This is a job for a Gas Safe Registered engineer.
    #312848
    Jazzmeister
    But yes it would be possible..maybe jet change required …But as was earlier said….if your going from lpg to nat gas…pipe sizing needs to be looked at and i assume it would be moved so you would need a Gas Safe Registered engineer to install it for you…..he would sort out everything on installation i would expect…..he may need to order new jets for you 1st though!
    Jazz
    #312849
    wsts
    Jazzmeister wrote:But yes it would be possible..maybe jet change required …But as was earlier said….if your going from lpg to nat gas…pipe sizing needs to be looked at and i assume it would be moved so you would need a Gas Safe Registered engineer to install it for you…..he would sort out everything on installation i would expect…..he may need to order new jets for you 1st though!
    JazzIts only possible if it was made to be converted, conversion is more than just a jet change, the tap would need to have an exchangable or adjustable by-pass.
