Stoves gas hob – tap question
Home Forums General Trade Forum Stoves gas hob – tap question
  • #45521
    Cras
    Is it a common fault on stoves gas hobs for the gas taps to seize up over time?
    My wife has owned an ovencleaning business for 4 years. A couple of weeks after one of her employees cleaned a hob, a customer had complained a tap has seized. This is not a normal occurance after a clean and the hob was working when the employee tested the appliance before leaving the customer.
    The customer has got a gas engineer going to look at the tap and I would like to be armed with some information as I know nothing about gas.
    Thanks,
    Cras.
    #285978
    helo_75
    it is becoming more common
    for years, they were never an issue
    i try taking the knob off and spraying a little bit of silicone grease down the shaft first and foremost.. quite often that cures it
    easy to change to be fair, but you have to be gas safe registered
    #285979
    wsts
    Re: Stoves gas hob – tap question
    Cras wrote:Is it a common fault on stoves gas hobs for the gas taps to seize up over time?
    With Stoves hobs no, I worked for them for over 5 years and very rarely needed to re-grease gas taps on hobs.
    #285980
    Cras
    thanks for the replies stoves engineer visted yesterday and the householder rang to say engineer says its deffo been caused by cleaning products used when my wife asked to speak to the engineer the householder said he wasnt willing to speak to her or put anything in writing on the invoice :rolls: im now mulling over my next move but in the meantime if you have to clean a stoves hob dont get cream cleaner or water anywhere near the thing cause one of the five taps will seize two weeks later 😆 cheers cras
