Stoves Gas Oven fault code
Home Forums Trade Technical & Spare Parts Forums Stoves Gas Oven fault code
  • #97623
    Kirk
    Help req with this fault code if possible, pnc 444440933 fault code 51-82 any help would be greatly appreciated, 🙂
    #468681
    kaibart
    Not much go wrong with gas ovens does this fault code come up straight away ?
    #468682
    Kirk
    It ignites and instantly goes out and throws the fault code up, switch the electric grill on does the same within seconds.
    #468683
    cant find any references for that one
    few in the owners manual
    https://www.manualslib.com/manual/10…page=37#manual
    found a ref to 51-71 which is a board fault
    Kirk
    Thanks Dave, I have drawn a blank everywhere, need a friendly Stoves engineer I think.
    #468685
    kaibart
    Does the fan run when you try to ignite the oven ? If not I would go for pcb board,failing that i would be doing an insulation check, also worth checking polarity on the socket its plugged into I’ve had them do all sorts of weird things when there’s a neutral fault, failing all that give stoves a ring and they might put you through to there guy in technical I’ve spoken to technical before
    #468686
    Kirk
    Everything works all be it briefly, Insulation and polarity was my first port of call, sure it`s something simple but I hate just throwing parts at things.
    #468687
    kaibart
    Give stoves technical a ring they are pretty good,only 1 other thing I would suggest checking is the micro switch on the valve/thermostat, I assume you have checked continuity on element and safety stat,and that you are still getting 240v to oven/ timer ?
    #468688
    Kirk
    Can close this post, Customer believes it`s unprofessional of me not to have the fault codes and she has been waiting 3 days, I politely told her to be on her way.
    #468689
    ” can madam please go and see a taxidermist on your own behalf “
