Hi all,
went to look at a this oven this week, It was cutting out on overheat stats because cooling fan had stopped running. Checked out fan, this runs ok if powered up independently. Changed fan control board for new but problem still exists ie the fan does not switch on. The fan control board is also connected to ignition control/spark generator . Both ovens and grill light and burn ok,ie flame is detected, that is until TOC cuts them off. Any ideas?
Thanks John
