stoves GL916 oven high flame will not turn down
Home Forums Public Support Forums Help And Support Cooker And Oven Forum stoves GL916 oven high flame will not turn down
  • #25463
    patz
    Hi ,i have a stoves oven (050504018), the door glass blown & had it replaced, then switched the oven on to full ok so far untill i went to turn it down i still had a high flame.
    then was told it was the thermostat, so had a thermostat fitted yet its still the same, so what can it be.
    #205959
    helo_75
    Re: stoves GL916 oven high flame will not turn down
    erm.. shaky subject gas repairs
    in honesty?
    u sure uve put the glass in the right groove?
    been to loads where ppl clean the glass, and then put it back in the back groove instead of the front, creating massive heat escape, and the stat dont register!!!
    try it, it might be that!!!
    good luck
    #205960
    wsts
    How long are you giving the oven before you turn the flame down ?
    #205961
    patz
    ar,two replys, (1) yes the oven glass is fitted in the right place thanks.
    (2) this time i left the oven on for about 5 mins & yes it turns down now but the old thermostat turned down in about 1 min can this be right,
    thanks for the replys so far.
    #205962
    Hi patz,
    Okay this one isn’t a DIY job, let’s make that clear from the get-go.
    You’re looking at the stat, which you say has been replaced, the oven thermocouple or the adjustment of it of, as a totally outside possibility, the flame failure device.
    There’s really nothing else it can be IMO.
    wsts
    patz wrote:ar,two replys, (1) yes the oven glass is fitted in the right place thanks.
    Your oven shouldnt turn down after 1 minute no, 5 mins is much more what I would expect,your oven will only turn down on temparature so if the oven hasnt reached the gas mark you turn it to the flame will be unaffected, have you actually tried cooking with the oven rather than just looking at the flame ?
    #205964
    patz
    yes it cooks fine, WSTS you say 5 mins is about right then i will go along with that, thanks WSTS & all the other replies,
