Stoves gs550 fan stays on all the time.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Stoves gs550 fan stays on all the time.
  • #75181
    Grover2000
    Hi can anyone advise what the problem could be this oven. The fan stays on all the time irrespective of the grill or o en being used
    Any help on the matter is greatly appreciated
    Grover
    #394165
    Re: Stoves gs550 fan stays on all the time.
    fans on ovens are controlled in 2 ways
    1 a thermostat that brings in fan when grill or oven gets hot and switches off when it cools down
    2 a circuit board that start when you turn the unit on and leaves the fan running for a given time after you turn off
    with you cooker most likely a circuit board but cant be certain as i cant find any results for your model
    suggest you contact stoves and see if there is a fan pcb on your model
