Stoves induction cooker no heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves induction cooker no heat
  • #92749
    slyp98
    Hi all this stoves range with an induction hob the induction elements will not work it just has ^ on the display, I replaced the cooling fan control board and thought that would sort it but no, anyone had this? I rake it the main module is the culprit
    444445385
    Mode is l sterling 1100E
    #452064
    Seamy
    Re: Stoves induction cooker no heat
    Mostly the Induction boards have cooked because of the design of where the fan initiation switches are located, i’ve done quite a few of these, all under warranty, but imagine the cost would be too expensive for a chargeable call to pay for.
    #452065
    slyp98
    Yeah I figured that Seamy, board at the front edge of cooker all the heat ,and the cooling fans at the back no ducting of any sort to direct the flow, I got quoted 165 EU plus vat from connect for the module but tbf a new 100cm range is 1200 eu I’d say they will go for it
    #452066
    slyp98
    I see what you mean now , the actual element boards are gone , just a little ticking from them when powered up ,
