Stoves model 058568000 (900Ea range). Grill not working.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Stoves model 058568000 (900Ea range). Grill not working.
  • #85951
    multiplexor
    Good afternoon,
    the grill on the oven above has stopped working and i wondered if anyone might have any suggestions regarding the problem. The grill will not turn on with the door in either the open or closed position. The element is ok and i have checked the micro switch, located near the left hand door hinge, which is also ok. The wiring from the micro switch seems to connect to a pcb at the back of the oven and i wondered if this is where the problem may lie?
    Any help or suggestions gratefully received.
    Many thanks
    Mike
    #429876
    multiplexor
    Re: Stoves model 058568000 (900Ea range). Grill not working.
    after looking on the internet i think that the pcb mentioned in my earlier post is a fan control module. Is it possible that this could stop the grill from working if it was faulty?
    Mike
