Stoves Newholme Range cooker
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves Newholme Range cooker
  • #45265
    Dual fuel appliance.
    The only model number I can find is 050564114.
    Called last week and found the fan oven element OC.
    Went back to fit it today and as soon as the power was switched back on the element came on whilst the regulator was switched off.
    Customer says she forgot to tell me it took the circuit breaker out last week. :rolls:
    So, how difficult is it to fit the electric fan oven regulator, will the huge beast have to be dragged out.
    Is it possible to change it without touching any gas fittings and last of all, does anyone know the part number of the right hand, electric oven regulator?
    cornflakes
    Re: Stoves Newholme Range cooker
    hi
    yes it will need to be dragged out,lubricate floor and look out for chain fixing at rear of unit, you need to remove back plate( isolate leccy first)
    if you remove all control knobs and timer buttons you can remove facis plate and just about remove regulator and thread new reg sensor under gas hob
    small hands will help
    #285071
    Thanks will pop back and have a look, she says it is on small wheels, hopefully that will make it easier.
