STOVES NEWHOME ALL ELECTRIC RANGE COOKER
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries STOVES NEWHOME ALL ELECTRIC RANGE COOKER
  • #70165
    richardable
    MODEL 58563011, S.N. 10805560.
    reported fault…no main oven fan.
    existing fan tests ok and works when connected (via teast lead) to mains.
    found that the mains terminal block had melted so replaced it.
    the elements heats but no fan. checked with WDS who says it’s likely to be the oven regulator/thermostat. there is a
    replacement kit (with wiring modification) retailing at about
    £90.00
    anyone had this fault and is a new reg/t/stat the fix.
    #377251
    rocker
    Re: STOVES NEWHOME ALL ELECTRIC RANGE COOKER
    As you mentioned the fan motor works, so you will need to trace the feed cable into t/stat and out to confirm if its faulty before buying parts.
