Stoves/Newhome dual fuel cooker DF600SI
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves/Newhome dual fuel cooker DF600SI
  • #26545
    Alanj
    Hi Guys,
    does anyone have dismantling instructions for this appliance.Have got to change grill regulator and oven thermostat. Any help appreciated.
    Alan
    #210549
    Alanj
    Re: Stoves/Newhome dual fuel cooker DF600SI
    sorry for being impatient guys, but does nobody have the information I requested? Please!!
    Alan
    #210550
    wsts
    You know the serial no, so I can have an idea how old it is ?
    #210551
    helo_75
    dont u just take the 4 plastic plugs out of the side of the hob( 2 on each side)? then the hob just lifts of…. simple
    #210552
    Alanj
    wsts
    S/N 005017.
    Alan
    #210553
    Alanj
    Thanks for the replies guys,
    I’ll check out the plastic plugs,but appreciate any other help.
    Alan
    #210554
    wsts
    This is more than likely a pre plastic plug version and its a swine, working off memory here so may miss something out but :
    Remove facia
    Will see 2 screws, 1 either side under the hotplate, remove them.
    Undo the screws either side of the hotplate that screw the side trims on.
    Next bit you can do the long way if you wish which is remove the lid and such till you get to a point that the hotplate will lift up and remove
    or
    the way I used to do it was lift the hotplate side trims to around a 45 degree angle, then put my finger in a burner and pull the hotplate upwards till it clears the flue trim…. job done and in about a quater of the time of doing it the other way.
