EF9600H Mod 058585102 Ser 50732954
This oven was dead, no display on timer/clock or functions even though there was power to it. Unplugged it and plugged it back in and it came back to life flashing up ER81 on the clock when it did so. I tested everything and all seemed ok.Got called back a month later with same fault, dead. Again unplugged and back in again and it comes back to life again with everything working, though this time it flashed up ER79.
Is it the timer/clock that is shutting this thing down and what are the error codes/
Any help please
Sorry but i’ve no info on eror codes, most Hobs & Ovens give a fault code when you renew power to them which actually means power has been disrupted. If its giving trouble, check the components & connections. Fan run on p.c.b on these have been known to be problematic, also the selector switch contacts overheat, even the lamp units short circuit blowing tripswitch.
