I have a Stoves Newhome SN60FP HAP0050 Model number 444448194
It recently lost power so I went to check the fuses, no issue with the fuses so I went to isolate the power at the main distribution board took the power down but then decided to switch the spur back on and the oven came back on. Grill and oven all appeared to operate ok, I then left the oven for a short period of time, the timer alarm kept resetting and eventually it seems to lose all power again the ring main spur is ok and no fuses are blown or tripped. rocking the spur off/on again resolved the issue periodically. When the oven is on the alarm doesn’t sound or power the oven down. As soon as the oven is place in the off position the alarm for the timer keeps resetting and going off and then the oven powers down. Is this a control board failure or something and I just better off replacing the oven than getting it fixed. Any support much appreciated.
Thanks in advance
Al
