stoves oven
  • #10841
    cornflakes
    RECENTLY VISTED A STOVES MODEL 05904159 OVEN
    This was resulting from my client finding out the actual problem, and deciding not to accept Stoves repair cost of £180.
    Fault: Bearings gone on oven circulation fan
    right simple job!
    obtains gen part and visits site, removes old wornout fan motor, fit new motor. Returns oven into housing…tests nothing other than the fan motor hovering. Removes oven, as sometimes spade connetors may not have fitted correctly.( or had we made connection!!! as I took 2 phone call in quick time)
    all fine.. test for voltage..nothing..gas ingniting, burner lighting, regulator working.
    now all I have done is remove 2 connections,( 3 screws and 2 cover plates inside oven ) and there is nothing.
    the old motor although noisy, I put back on same symptom..hovering motor( right to left)
    gob smacked or what..
    any ideas welcome
    Graham
    Leicestershire
    #142913
    Bryan
    Re: stoves oven
    Graham
    Not exactly sure what you mean by “hovering motor left to right” when you are getting no voltage at motor terminals but have you set the time clock and are you testing it with the door closed (door interlock switch ? ).
    Seems obvious but it is Friday afternoon 😆
    Bryan
    #142914
    cornflakes
    Re: stoves oven
    yes bryan it is friday pm, but i am not affected by the day of the week I think, although I was in london on the thursday stuck in a car park, called regents street for 2 hours after the bomb scares.
    back to early problem on wednesday last
    door is closed,timer is in manual mode, motor hovers ( very very slow motion of fan) as if start windings are trying to kick in, but only whilst ingnitor is sparking up, when main gas burner is lit, motor ceases to show any motion. and no voltage!
    graham
    #142915
    Dave_Conway
    Re: stoves oven
    If this is the type I think it is (no Stoves info to hand here at home)…
    It’s probably the PCB in that case, I’ve had a few of these fail doing just that.
    Oddly though, it shouldn’t even attempt to ignite until there is sufficient pressure within the cabinet after the fan has fired up 😕
    All points to the PCB I reckon.
    #142916
    cornflakes
    Re: stoves oven
    dave
    many thanks
    what is perplexing about this repair is the fact the fan was working fine, although noisy before i dismantled and fitted new motor.
    with power off, how on earth can PCB blow.
    looking at the wiring diagram the live feed is from PCB via door interlock and solinoid valve, I am revisiting to do continuity check on wiring
    Graham
